hold light flashing help please help me
I have mazda car 1994, sentia...
the hold light is flashing , and my car doest work, it give self , but its doest start. I changed the delco + coil , but the problem still there help me please my life is nightmare, no body know what the problem is pleeeeeeze help :( |
hold light blinking
I have a 94 mazda 626 and the hold light was blinking and it wouldnt shift above second gear. the dealer was a lot of money to tell me the problem. i had my uncle look at it because i was told the cilynoid wire could be pinched what ever that is but he fixed it. hope that helps
check for spark and gas on the plugs. if there's no gas, maybe the injector connection plug is loose, or the fuel filter is plugged. get a manual from the library and read the tuneup section. :)
Originally Posted by greasegeek
(Post 156537)
check ATF fluid level, replace ATF fluid and filter, check electrical connections and cross your fingers. but most of all, micholson: don't answer posts that are 5 years old. ;-) |
Had the same problem, blinking "hold" light. We disconnected the battery for 24 hours
and the problem went away. Hold light no longer blinks and the hold button works as it is supposed to. Don't ask me?? mike |
Hi...it could be that your car has a bad connection. Do this, connect a bypass line from negative terminal to gearbox case and try starting.
| All times are GMT -5. The time now is 05:56 AM. |
