hit a big bump now 91 626 wont start
Old Mar 20, 2006 | 01:06 PM
jakejohn's Avatar
Default hit a big bump now 91 626 wont start
I was driving home and i went over a big bump kinda fast then all my dash lights lit up and my car died right away. Now it will turn over and sometimes catch for a second then die, or it will just keep turning over i was told it could be the fuel pump. Does anyone have a clue what is wrong?
Old Mar 21, 2006 | 10:15 PM
dave87's Avatar
Default RE: hit a big bump now 91 626 wont start
Is your battery properly connected ??? check to see if the fuel pump is working... and easy way to do it if your by yourself is to take off the distributor cap and turn the rotor lightly with your hand and you will hear a little buzzing noise... if you hear it you fuel pump is working!
Old May 13, 2006 | 09:54 PM
shinze's Avatar
does it have a fuelpump shut-off switch and if it does check it it should be in the trunk behind one of the panels. Some cars have those in case of an accident to keep fuel from catching on fire, try that i hope i helped.
Old May 14, 2006 | 05:38 PM
Larry 62694's Avatar
Check all your relays and fuses you may have made contact with the battery (+) to metal or a battery cable (+) to metal and shorted it out, maybe cut through the insulation of the cable.
Old May 14, 2006 | 11:20 PM
bkey71's Avatar
The author of this post has never replied in 2 months so I bet he won't answer.
rags2bitches
Apr 19, 2012 11:47 AM
friendlynerd
May 22, 2009 10:08 PM
rponycar
Oct 24, 2007 01:46 PM
Quadfather
Dec 7, 2006 09:07 PM
chefskitty
Oct 15, 2006 01:18 PM
