2000 mazda 626 LX 2.1 that just died
Old 02-02-2017, 01:54 PM
2000mazda626's Avatar
Default 2000 mazda 626 LX 2.1 that just died
So on my way to the store my 2000 mazda 626 died out of nowhere it kinda had a rough idle but ran fine once moving when it died on me I tried starting it again and all it did was clanck and die again it hasn't started up again since I'm looking at the timing belt now but it looks good it moves on the wheel fairly easy don't know if that's good or not I also ran a code reader on it and I got code P0420 please some help would be great
Old 02-04-2017, 04:06 AM
P0420 is related to the catalytic convertor &/or O2 sensors.
When you turn the key what actually happens? Does it wind over? Slowly? Fast? Noisy? Quiet?
How's the oil level? How's the coolant?
What do all the spark plugs look like?
Are the camshafts still timed up to the crank?
Does it have fuel pressure?
Does it have spark?
Compression test?
Old 02-04-2017, 08:14 AM
Default What it does
Does it have spark?
Compression test?
So when I try and start it it wants to buy won't right after it died I started it up again and the was a scraping/grinding I just did a flush and oil change on it within the last month so both are fine spark plugs look good a little black but not oily my dad thinks it might be something to do with timing wether it's that or not it's getting replaced not sure how to check the fuel or compression but I'll figure it out I'm determine to fix my car and I appreciate the advice any help is greatly asked for
1998mazda626
07-19-2013 10:55 AM
everythingzen
07-11-2011 10:43 AM
rallenm
08-07-2010 12:40 AM
Camo4x4
07-30-2008 11:25 PM
Metric
09-06-2006 12:15 PM
Quick Reply: 2000 mazda 626 LX 2.1 that just died
