-   Mazda 323,Mazda 626 & Mazda 929 (https://www.mazdaforum.com/forum/mazda-323-mazda-626-mazda-929-24/)
-   -   ECU Urgent Help Needed (https://www.mazdaforum.com/forum/mazda-323-mazda-626-mazda-929-24/ecu-urgent-help-needed-31190/)
SilverSpear Mar 8, 2013 12:16 PM
Hello guys, this is my first post around here.
I always hate to start with needing a solution to a problem, but I am desperate.
A month ago, as I was leaving for work, tried to start the car and nothing happened. I left with a coworker, and called my mechanic (friend) to pass by and check what the problem was. Bottom line, ECU caught humidity and was killed.
I am trying ever since to find a replacement without much luck. Making things simpler, here is a picture of my ECU.
http://imageshack.us/a/img59/2817/img20130220wa000.jpg
I cannot find the ZM12 ECU anywhere. Can any of the Mazda gurus around here help me find a solution? Can I fit another ECU code?
PLS HELP!!
Kevinkpk Mar 8, 2013 01:45 PM
I don't know where you are located. Unless the electronics are shot, have it reprogrammed.
SilverSpear Mar 8, 2013 02:12 PM
I am located in the Middle East. I removed the ECU and took it to a specialist shop, it turned out that the previous owner also dealt with it before me, and had a very poor job on the electronics. So now, no one is willing to touch it.
I can find on ebay lots of ECUs starting with ZM02, ZM01, ZM35, etc... do you guys think one of them can work?
Any help is appreciated.
Kevinkpk Mar 8, 2013 02:42 PM
Too me these listed are either upgrades or physical difference in them. Only thing I can offer is get detailed info from ebay seller regarding physical size, pinout ect. If it is a match for your zm12, contact your ecm specilaist with your vin to have that replacement ecm programmed for you vehicle.
Kevinkpk Mar 8, 2013 02:48 PM
You might try these people.
PartsOnNet.com Used Auto Parts, Salvage, Recycled car parts Remanufactured, ne
