Diagnostics
Does anyone know where the Diagnostic is located for 95 mazda 626 and what kind does it use odb I,odb II, or what. If odb 2 what protocol?
RE: Diagnostics
95 626 uses two different data link connectors for retrieving engine codes, neither of which are OBDII.
Both connectors are up by the battery. 4 cyl ATX used a Ford style connector that you would need a star tester or other older Ford combatible tool to get codes. The 4 cyl MTX and V6 engine both use a square box that has DIAGNOSIS letter across the top. Code retrieval with this style is done by grounding the TEN pin, turning the key to run position and counting the long and short flashes of the CEL. Below is what the Mazda style looks line when cover is opened. [IMG]local://upfiles/1377/26725F785C0D49E689AD796572735500.gif[/IMG] |
RE: Diagnostics
I connected the wrong one now my car doesn't work. The engine starts but i don't have any stats. Like the RPM and I can't change gears.
RE: Diagnostics
nvm . blown 15 fuse
