dash brake light
Old Mar 14, 2012 | 07:34 PM
Lightbulb
Ah!! I just remembered....
The V may recenter itself since the pressure in the system is now equal, but the plunger for the switch is not liable to reset itself. Therefore the fix (and it's an easy one) is to remove the switch, pull down on it's plunger and reinstall.
Old Mar 14, 2012 | 07:47 PM
rprice32@bellsouth.n's Avatar
It's gotten dark on me here so I'll check for that tomorrow afternoon, Virgin1. Thanks for the suggestion and I hope that is the fix. I just can't get the rear calliper to start engaging when the brakes are pumped.
Old Mar 15, 2012 | 07:42 PM
How'd you make out?
And to answer your other question: It doesn't matter whether or not the engine is running when bleeding the brakes. Though you have a power "booster" that's all it is. there is still a physical connection (linkage) between the brake pedal and the master cylinder.
It truly sounds like the balance block has shut down one half of the system due to a pressure imbalance during the pad install. I suggest you find it, pull the switch and recenter it manually. A small screwdriver should do the trick. Then try bleeding the brake system.
VABeach
Sep 15, 2013 04:15 PM
schlompie
Mar 6, 2012 02:49 PM
MX691
Feb 11, 2010 05:19 AM
stan2005
Oct 22, 2006 04:38 PM
