burning oil worse after valve cover replacement
i replaced the valve cover gasket and the seals on my 626. Now it's burning oil WORSE than before and smokes up the whole place, and I can't find any leaks. It takes a couple minutes of driving before the car finally stops smoking. Also my check engine light is OFF and I can't figure out what i did wrong
any ideas of why this is happening |
what engine does the car have and how many miles and one more thing has it been doged
Did you seal the required areas with RTV?
Reg |
What about your PCV? Pull it and check that it rattles. Did you plug in back in the the correct sense?
if it is burning oil but stops after driving a bit it is most likely valve seals
