broken ring
is it possible to remove pistons in a 1.8 from below without removing the engine? thanks.
Technically yes, but alot of effort. You would need to remove the transmission, then the sump, then the crankshaft. or remove the sump, then the cylinder head.
(Post 160593)
The Pistons are bolted to the crankshaft and it bolts to the transmission.
