Brake light
Umm ok ive still got the Mazda 626 1993 and when i push on the brake pedal the rear brake light lights up and sometimes flashes... The back lights seem to be working fine help !?!?
RE: Brake light
ok now it doesnt flash anymore it just lights up when i hit the brake....
RE: Brake light
I do not quite understand the question. What is flashing and what is working correctly?
RE: Brake light
When i press the brake pedal... A red light on the dashboard lights up for the period that my foot is on the brake pedal everytime and turns off when i release the brake... The red light says "rear" if that helps any...
RE: Brake light
It sounds like a problem with a bulb burned out. The easiest way to check is to put a stick to hold the brake pedal down between the pedal and seat. Check to see that all bulbs are on even the center high mount brake light.
RE: Brake light
Ok so its not a burnt out bulb... So could it be a ground problem or some loose wireing somewhere ??
RE: Brake light
When I use to work for Volvo, this was a common problem. Even if all bulbs were working, we had to make sure all bulbs were the same brand and color for the brake lights. By color I mean the color of the base, some are brass and some silver color. The circuit that monitors bulbs was very sensitive to a mix of brands of bulbs even if they appeared to work correctly.
RE: Brake light
oh ok i see what you mean!! One of the bulbs was the wrong color so i changed it... Thxs!
