95 mazda 626 2.0 rough idle
I recently purchased a 95 mazda 626 with a 2.0 automatic transmission. It has terrible problems idling it idles too low 500 rpms, too high 2000 rpm's. My mechanic replaced a heat sensor on the engine. It is a little better, but idle rpms are still all over the planet.
He belives it is the idle air control valve?????
Please help with any recommendation.
Thanks
vffdoug
Thanks
vffdoug
Sounds probable. I would check for vacuum leaks first. Also clean the MAF hotwire and check the thermostat. If it sticks open it can think its a cold engine and bump up your idle. I'm sure he has already cleaned the throttlebody out.
dirtyedge
May 2, 2007 06:02 PM
