93 mazda 525 4cyc starting problems
heres the deal....i have changed the fuel pump....distributor....fuel filter......and Computer.....my 93 mazda 626 is a 4 cyc....it will not start....it doees crank....when i spray starter fuild in the air box the engine will try to start.....can any give any tips?
RE: 93 mazda 525 4cyc starting problems
ok first of all dont spray starter fluid in your air box... its not magic it wont make your car all of usudden start... did you set the timeing corectly on your distibutor?? do you get sparks from your spark plugs or wires ?? I recently had the same problem with my 93 626 4cyl and it was basicly the ignitor in the distributor that was the problem.. changed the dizzy but you have to get the timeing perfect in orer for it to work.. bring the engine to TDC and turn the rotor in the middle of that weird bump on your distibutor.... this should work if your engine starts but is running ruff move the dizzy from left to right with small movements until it is perfect... hope that helps!
The engine is getting spark......the reason i sprayed the starter fuild was to see if the engine was getting fuel....the engine is in time....
Do you know if you have fuel pressure? Is the fuel pump turning on with the key?
RE: 93 mazda 626 4cyc starting problems
it does not sound like it is.....that is what i was thinking......maybe the fuel pump is not getting voltage or something.........does anyone know an easy access for the voltage wire going to the fuel pump.....(hoping to access them and aviod taking the fuel tank down)
| All times are GMT -5. The time now is 09:36 AM. |
