92 929 (all insturments and warning lights dead)
I got this car in a non running condition, took me a bout 3 days of messing around with it to get it started. All the indicator lights to the left and right of the guages are dead now, as well as the shift indicator and hold lights, The tac is dead as well as the spedo. These were all lite up before i finally got the car started.
I also have to push the shifter unlock button to shift out of park. I have check all the fuses under the hood and in the car, the illum fuse from the inside of the car test good, what other relay controlls all of this. The car runs like crap if you try to drive it, like the Computer is messed up, I can't pull codes because no check engine or any other lights come on. Thanks |
RE: 92 929 (all insturments and warning lights dead)
bump, Anybody?
Check the junction block at the fire wall for corrosion/mouse damage. That's were a large portion of your wires and power comes through.
If it's been sitting awhile I'd be looking for a 'common area'. It usually (<---- keyword)comes apart pretty easy: a single screw in the center and pull. Other than that, can you find/use a 'known good' computer? Or a junkyard special? I might be leaning toward that, or, if it has one, the BCM (Body Control Module). '92? I'm not positive it has one but those are what usually controls all the fancy stuff (air bag, radio, memory seats, shift lock, etc...) Without looking at it it's hard to say, so I offer this for now. |
