'92 626 power antenna
i am hopeing someone out there knows how to replace the power antenna on a 92 626. it is mounted on the driver side,under the A-pillar behind the fuse box. i need help as to how to remove the actual antenna from the motor. thnx in advance.
RE: '92 626 power antenna
Having replaced quite a few masts on these cars with the a-pillar mounted antenna, I would seriously advise you to consider having it replaced by a dealer or good aftermarker stereo shop. It is one the most dreaded jobs to do due to the lack of space to work and trying to get new mast fed back into the motor. The entire fuse box will need to come out to even see the motor and if you are not careful the relay can be damaged. Might consider putting a plain old manual style mast in. Believe me, you will thank me later!!!
I have same car, same problem, I just pulled the antenna out a couple of feet and the radio works good, I was surprised.
Jim |
