323 gtr
The engine "cuts" right before the turbo charges.
The idle is good, easy started and it runs normally until the turbo should charge. Just start to "farting" at around 3000 rpm, or if i try too accelerate uphill. Parts i have checked and replaced: Checked for any leakage. Checked the turbo for slack Coil, spark plugs and wire. Distributor, ECU. Fuel pump and filter. Fuel pressure regulator, PRC solenoid valve. Temperature sensors, airflowmeter. Sorry for bad English. im from norway :p |
