2004 626 fuel pump diag help
Hello Mazda forums !
For my first post, an oldie but a goodee. My 2004 626, 2.0 currently is in a no start mode. Suspect fuel pump, it runs on either. My problem is I cannot find, (identify) the fuel pump fuse or relay. Both fuse panel at the lower left drivers kick panal and main relay center under the hood fails to list any relay or fuse as for the fuel pump. Closest it gets is "injecto I have tried every source possible, the best case scenario is the poster thinks that so and so fuse or relay in a picture they provide is the one, but none of mine are the same. So, in the accompanying picture I took accessing the pump I an trying to check for power at the pump but cannot find the correct info on the colors present to see which ones are for the pump. Any help would be greartly appreciated. https://cimg4.ibsrv.net/gimg/www.maz...c6cab31a8e.jpg How I spent my Friday night... correct info on the colors present to see which ones are for the pump. |
