1995 mazda 626 gets no power from the fuse box
Old Jan 4, 2007 | 11:37 PM
bs24's Avatar
Default 1995 mazda 626 gets no power from the fuse box
I have a 1995 Mazda 626 16 valve 4 cylinder. It was run off in a ditch then drovehome and parked, and never would start back. None of the lights or anything work. When you cut the key on it does nothing. Any idea what might be the problem. Mabey a shut off switch or something?[sm=helpout.gif][sm=helpout.gif][sm=helpout.gif]
Old Jan 5, 2007 | 04:24 PM
babyhuey's Avatar
Default RE: 1995 mazda 626 gets no power from the fuse box
Try checking the 100 Amp MAIN fuse in the underdash fuse and relay box. This fuse will not pull out of the fuse box like the others as it is bolted in with 2 10mm bolts at the base of each fuse leg.
shaun ayres
May 21, 2010 11:32 AM
Jacksong03
Oct 30, 2008 06:01 PM
longrange
Nov 26, 2007 01:13 PM
sonnybungay
Sep 20, 2007 01:39 AM
bart_man
Apr 9, 2007 09:26 PM
