1991 626 Won't turn over
Ive got a 1991 626 dx and it doesn't seem to want to turn over. I got a new battery for it and it does nothing. When you turn the key in the ignition all the interior lights light up but when you turn the key all you hear is a single clicking noise and the lights dim. It doesn't even attempt to crank over at all. Any help would be greatly appreciated.
Thanks |
RE: 1991 626 Won't turn over
It sounds like a possible bad connection somewhere. I would check to make sure the battery cables are clean and tight. If the battery has been corroded on the posts in the past, the cables themselves can be faulty and cannot handle the load. If the car has a standard trans, you can push start it to make sure it will run. Another possibility is a starter or switch.
The battery cables were pretty bad. Pretty much white. Do you clean them with a wire brush or replace them typically? From what I've heard the starter switch is a pain to replace because its behind the steering wheel and all that junk. Any pointers on replacing it? Its an automatic so I'm not able to pop start it.
Thanks a ton for your help. Right now im financially in no position to get another car. |
If there was a lot of corrosion, it can get inside the cables causing excessive resistance. It does not matter if you clean the outside of the cables in this case. The best way to try and clean them is with some baking soda mixed with water. Make this mixture in a plastic cup and dip the cable ends in for a good soak (after removing from the battery). This will help clean and neutralize the acid. DO NOT try using a wire brush on the DRY corrosion, it will burn your nose and throat. I would try this before the switch.
i have a 96 626 had the same prob a year age check your alt
It did turn out to be the alternator.
Any idea if two hours of labor at a shop is too much? How difficult is the job? Alternator buried in engine bay? Thanks |
Originally Posted by downontwo
(Post 21729)
Thanks |
1991 626. Trying to find the specs for the valve springs inlet/outlet. min/max length
Originally Posted by Chrispen
(Post 131255)
