What happens to a head in a machine shop
17 Attachment(s)
What Happens to a head in a machine shop
First Not all shops have the same equipment and the procedures from one shop to the next can and will differ. Some shops cater to domestics and others imports or even diesels. Some shops will view everything as a “stock” rebuilds. So…. The most important thing to know is the shop you use and the equipment they will use. The subject head is a Mitsubishi 4G63 7 Bolt The first thing that should happen is the machinist looks at the head. Checking for the obvious damage, broken bolts, stripped bolt holes, bent valves, ect. Attachment 4655 At this point it is up to you as the customer, inform the shop what you want done, such as… 1) Pressure test for cracks 2) Valve job 3) Surface 4) Guide work 5) Any performance work wanted Also now is the time to speak about who will provide what parts, valves, seals, guides, springs, ect. Now the shop should be able to give you, the customer, an approximate estimate of what the parts and labor will cost. You as the customer have the choice to agree, or go somewhere else. Now that your head is at the machine shop, and you have agreed to have the work done. The first thing to happen is the head will be disassembled. The tools needed are Attachment 4656 Wire basket for small parts springs, valves, ect Small container for valve locks Valve lock release tool (socket method) Hammer 10mm socket 12mm socket 12mm socket Ratchet 5.5mm allen bit socket or wrench Pocket magnet Long reach needle nose pliers w/45* bend Impact gun (not pictured) Cam gears come off first, use impact with the 17mm socket Attachment 4657 Next remove the cam tower caps, use impact or ratchet w/12mm socket. Start at the ends working towards the center Attachment 4658 Attachment 4659 Once the cam caps are removed, lift the cams out. Attachment 4660 Next lift the roller followers out Attachment 4661 Now you can remove the HLA’s Attachment 4662 Attachment 4663 Now remove the oil spliter Attachment 4664 Now remove any other small bolts Attachment 4665 This is a “heat tab” Most machine shops use them. The center will slide down at 240-250* and totally dissolve at 260* Attachment 4666 Next is to remove the valve train. Yes the same method that a lot of DIY people use are used in a machine shop. Use a basket and a paint cap, have a pocket magnet handy too. Attachment 4667 Have your “tool” and hammer ready to go Place the tool on the spring retainer and give it a firm whack. The locks will stay in the tool and release the retainer and spring. Place the retainers and spring in the basket Attachment 4668 Fish the valve locks out of the head casting with the pocket magnet. Attachment 4669 Place the valve locks in the paint can cap. Attachment 4670 Now remove the spring seats with the pocket magnet and place in the spring basket to be cleaned. Attachment 4671 |
18 Attachment(s)
Next roll the head over and remove the valves and place in the basket.
Attachment 4637 This head was rebuilt once before, it must have had bent valves.So I will change the valve guides. Now roll the head back over and remove the valve stem seals, throw these in the trash. Attachment 4638 Next grab the 5mm allen bit and remove all the oil galley plugs. Keep these to be installed later, place in the paint cap with the valve locks. Attachment 4639 The last thing done is to remove the cracked valve guides. Attachment 4640 Now that the head is fully stripped, it can be tech’ed First thing is to do a quick clean on the head gasket surface. Attachment 4641 Next is to measure head thickness. Attachment 4642 Now to check to see how bad the head is warped. Attachment 4643 Notes are taken to reference back too. Attachment 4644 If it all checks out, it goes to cleaning. It gets thermal cleaning, then glass beaded. Attachment 4645 Next oil port mod #1 is done Attachment 4646 Next all the oil galleys get gun brushed Attachment 4647 Now the entire head will be blown off with compressed air, including every bolt hole to make sure there is no glass bead media is left in or on the casting. Attachment 4648 next is a coat of spray paint to seal the casting. Attachment 4649 Now new guides can be installed. Attachment 4650 They are set to height. Attachment 4651 Now the valve seats can be cut. Fist is to set the head in the machine and secure it properly. Attachment 4652 The proper sized pilot is selected. Attachment 4653 The head is now leveled in the machine. Attachment 4654 |
16 Attachment(s)
Now to set up the seat cutter.
First is to find where the seat is to make contact on the valve. Attachment 4621 Now the cutter bit can be set. Attachment 4622 The seats are cut. Attachment 4623 Now the valves are lapped. Attachment 4624 The small parts of he head have been cleaned, retainers, springs ect. Attachment 4625 Valve springs are tested. Attachment 4626 Most valve springs have been found weak, so New BC1100 springs will be installed (stock spring on left, BC spring on right) Attachment 4627 A broken exhaust stud was found and removed. Attachment 4628 The valves are ground. Attachment 4629 Ground and ready to be installed. Attachment 4630 Now the head can be surfaced. The head is set up and secured to the milling machine. Attachment 4631 The proper surface finish is milled for the head gasket to be used. (a composite for this one) Attachment 4632 The head is now blown out to remove metal flake from milling and seat cutting. Now that the machining is done, it is time to assemble the head. Valve tip height is checked to make sure it is in spec. Attachment 4633 The valves are removed, lubed up and slid back into the same hole they came from. Attachment 4634 A package of valve seals found in a head gasket set. Attachment 4635 Now the seals are pushed on by hand Attachment 4625 Now seals can be installed, this is my “hi-Tech” seal installer. |
15 Attachment(s)
Attachment 4606
Now the seals are tapped into place securely. Attachment 4607 Now spring shims are installed if needed. Attachment 4608 The spring shim goes on before the spring seat. Attachment 4609 Now the cleaned spring seats are installed. Attachment 4610 On top of the spring shims. Attachment 4611 The new valve springs, BC1100 Attachment 4612 Now the new BC1100 springs are placed in the head, on the spring seat. Attachment 4613 I will set the head back in the TnS 2000 Seat and guide machine, Using this adapter I will compress the valve springs. Attachment 4614 Now before I compress the spring, I will take the valve spring retainer. Attachment 4615 Install the valve locks, Attachment 4616 Then place it on top of the spring. Attachment 4617 Now with the spring and retainer compressed, Attachment 4618 I can push the valve locks into place. Attachment 4619 Repeat the process till all the springs and locks are seated properly. Attachment 4620 |
7 Attachment(s)
Now this customer is going to install new 3g HLA’s. So no need for me to install the last of the valve train.
I check the valve to seat seal one last time. Attachment 4599 I did install the cam tower caps on their proper side and position. Each cam tower bolt received a quick dip in oil, since all the bolt threads are dry. Attachment 4600 Now the oil galley plugs received a dab of sealant. Attachment 4601 Then started by hand to prevent cross threading. Attachment 4602 Then tighten to seal. Attachment 4603 I measure the head for thickness and make a not of how much was removed. Attachment 4604 The final step is to CC the combustion chamber so proper compression ratio can be calculated. Attachment 4605 This head is now done, and ready for the customer to pick up and install. |
Just another day at the office, eh!
How many hours for the process? Did you get my P.M.'s yesterday? |
(Post 135358)
How many hours for the process? Did you get my P.M.'s yesterday? From tear down to being bolt on ready, a stock head will have 4-6 hours into it. Depending on the head some can have as much as 12-14 hours like a 2JZ, but that includes setting the cam lash. SBC stock heads can be done in about 2-3 hours, they are simple and sloppy, A set for dirt track about 4 Now a 4 cyl 16 valve DOHC, with bronze guides, and full port work, fitting over sized valves I can have 25-30 hours. More if I had to developed a custom spring set up, or work up specs for custom ground cams. Yes I did get your PMs, just did not have time to get into them yesterday. |
| All times are GMT -5. The time now is 05:36 AM. |
