Replace ATF at 130k, good or bad?
Old Mar 6, 2020 | 12:34 PM
dbelcourt's Avatar
Default Replace ATF at 130k, good or bad?
Hi,
I got a used 2009 Mazda 5, minivan. It's got a little over 130k miles on the automatic transmission. I don't know the history of the car so I don't know if the ATF ever been changed or flushed. It's working fine now.
I piked up some Idemitsu type M ATF, a transmission filter and pan gasket. Planning to replace the filter and only replace about half (4 quarts) of the ATF.
Has anyone regretted doing this?
Thanks,
DB
Old Mar 6, 2020 | 01:12 PM
It is a straight forward not difficult DIY service and there are no done sides. While the pan is off you will be able to see if there is a residue on the valve body by simply wiping it with a clean white rag. If there is then consult a shop that specializes in transmissions and see what they recomend for you based on them seeing your vehicle first hand.
dblackmanc
Aug 10, 2018 09:47 AM
mig25
Oct 20, 2014 02:27 PM
orangeRcode
Aug 10, 2012 04:31 PM
rob289c
Sep 7, 2011 08:14 PM
Krameryah
Feb 14, 2010 07:44 PM
