Rear axle removal question
Old Mar 7, 2024 | 02:55 PM
Coopers's Avatar
Default Rear axle removal question
I have a 1988 Mazda b2600 4x4 in Australia and it has a leaking rear axle seal. I have a new seal to replace the old one but when I searched the internet to work out the easiest way to remove the axle I found my differential assembly does nor have the removable plate on the back of the housing. I’m sure there will be bolts behind the brake assembly that need to be removed and I assume the axle will slide out with the aid of a slide hammer. Once removed do I need to press off the wheel bearing to remove the axle seal. Any advice is greatly appreciated. Cheers Coops
Paul1975
Jul 15, 2023 01:28 PM
Rweaver
May 31, 2023 02:37 PM
motocam360
May 29, 2023 01:59 PM
2names
Apr 3, 2019 07:55 AM
sstockton
Aug 15, 2007 05:51 PM
