Overheating
Old Mar 9, 2009 | 03:14 AM
crainb's Avatar
Default Overheating
Hi all,
First post ever. Still figuring this stuff out. I had a question. I have a 1998 Mazda 626 LX-V6. I am pretty sure my cooling fan is supposed to kick on every once in a while but it never does. I can't figure out which dohicky is the temp sensor though to check it out. The fuse is good and i have already replaced the fan itself. Can't find any good pics to help me out. Thanks for any help.
CR
Old Mar 9, 2009 | 03:25 AM
Does it come on w/the A/C? It should be on all the time then.
Is the car actually overheating or are you just worried about it?
Old Mar 10, 2009 | 07:23 PM
crainb's Avatar
Unhappy Overheating
The temp gauge is getting almost maxed out. I am losing coolant also. Tonight I crawled under the car and there is a slow dripping of coolant. I am thinking that my water pump is almost done for. Problem is I can't identify which pulley is for what because it is pretty cramped. If I have to replace the pump do I have to pull the engine? If I pull the engine should I just rebuild the engine? Should I make it easy and buy a replacement?. Is that something I can do or should I have a shop do it. The exhaust is getting smoky too which I think means a blown head gasket.
All in all I may just have to break down and buy an new 6. Shame.
Thanks for your help already.
CR
Old Mar 30, 2009 | 07:20 PM
mikekuni's Avatar
um yea... either blown gasket, rings or cracked wall. there are other ways that could contribute to smoke. do a compression test. that will narrow it down for you. if the compression is down on just a single cyl. then its prolly either cracked wall or rings. if there are 2 cyl. next to each other that is low comp. its prolly head gasket. lmk if u need any more info. im not a master tech so dont think i know alot hahaha.
danattamco
Apr 26, 2006 04:09 AM
cbg
Jan 3, 2006 09:27 AM
Gnashing
Oct 10, 2005 11:21 PM
supabenben
Aug 31, 2005 08:29 PM
muddytazz
Jun 19, 2005 02:55 AM
