no heat
I just had a loss of heat today on my 98 Mazda Millenia. Worked fine at startup and I turned it down. I tried to turn it back up and now no heat at all. Air and fan work but no heat. I have no Idea what it is. I jhave loked in the owners manual and there is no troubleshooting section on this.
Anyone have any ideas.
I also have a problem with the tilt steering wheel. It works intermittently and at times gets stuck in the wrong position. The manual adjust switch works intermittently. I have taken to leaving it in one position and not using the adjust. Sounds like a switch. It this a owner or dealer fizable problem.
Thanks,
Mike
Thanks,
Mike
Hi,
I had the same problem on my 929. Operators manual does not tell you nothing. They want you to take car to mechanic and pay some greasy dude$80/hr.I would check to see if the thermostat is working (lets water/coolant flow through engine and heater core therefore producing heat). Also, I would flush out both the radiator and heater core. Maybe it has corrosion in them.
CO2Man [8D]
CO2Man [8D]
