minor tranny problem
Old Oct 19, 2007 | 01:00 AM
show_stopper's Avatar
Default minor tranny problem
my transmission grind a little in 2nd and 3rd if you shift too fast, and its hard to get into 1st. i think its my syncronizers but my friend said the clutch. it goes into 4th ant 5th fine. it just started grinding in 2nd. any ideas on what it is?
Old Oct 19, 2007 | 08:08 AM
hixx's Avatar
Default RE: minor tranny problem
The pilot bearing could cause that which would require removal of the trans and comes with a clutch kit. Synchro problems are rare,Pilot bearing would be the most common then the sleeves that mesh with the synchro would be a close second. I would pull the trans and check the pilot bearing. If it is in good shape an overhaul would be in order.
Old Oct 19, 2007 | 01:16 PM
thanks for the tip. is the clutch a simple replacement in this car, or should it be done at a shop? i dont do much if my own eingin work.
Old Oct 19, 2007 | 02:43 PM
hixx's Avatar
It is fairly involved. The trans must be removed.
08Mazda6
Jun 27, 2009 11:22 PM
blondie
Dec 6, 2008 02:14 PM
mazda guy
Nov 19, 2007 09:21 PM
Oh6sixXx
Sep 26, 2007 09:47 PM
SNM
Aug 17, 2006 01:35 PM
