Mazda 6 2.2 diesel r2aa 2009 engine timing
Old Aug 16, 2018 | 04:03 AM
Rattler's Avatar
Default Mazda 6 2.2 diesel r2aa 2009 engine timing
I have just replaced my engine and it will not start. I have gone through loads of checks to try and find the problem i am now checking the timing (as the garage changed the timing chains prior to dispatch) the cam and crank appear to be timed correctly, however the balance shaft appears to be 180 degrees out none if the marks line up.
My question is with the main timing marks lined up at top dead centre should the balancer marks line up or do i have to rotate the engine through a further 180 deg to line the balancer timing marks up if not how do i set up the balancer timing?
Would the balancer timing prevent the engine from starting? Thanks a lot
Rattler
Aug 13, 2018 06:55 AM
Rattler
Jul 23, 2018 04:56 AM
Steve Walsh
May 27, 2018 07:32 AM
landlord
Jan 9, 2011 07:33 AM
