left side indicators, mx5 eunos
I've found that all the left side indicators and dash light don't flash when i indicate left but click very fast. right side ok. when i press the hazzard lights the right indicators flash at a normal speed but not the left.
the problem was intermittent and could be fixed with a bash on the dashboard but is now permanent. I wonder if it's a connector somewhere that's corroded because I've had lots of water in the left foot well. anyone have any ideas as to how to find out where the problem is??? many thanks |
When you put your hazzard lights do all the indicator bulbs flash? . If they do then yes you might have a problem with the wiring or even a faulty switch. I would also reccomend that you check your feeds to the indicator relay and check the pins to it for corrosion.
