Hazing headlights
Old Nov 19, 2005 | 12:17 PM
B3K's Avatar
B3K
Default Hazing headlights
My headlights are hazing. Can something be done about this ?
Old Nov 19, 2005 | 12:32 PM
DropTop88RX7's Avatar
Default RE: Hazing headlights
there was a thing for 2G mitsubishi Eclipses. the ones that they talk about are rock chips that cause the hazing. if i can find the fix, ill setup a link. is yours the same way with rock chips, or is it mist on the inside?
Old Nov 20, 2005 | 12:38 AM
bkey71's Avatar
I also have the same problem on my Protege, they look hazy on the inside.
Old Nov 20, 2005 | 11:39 AM
B3K's Avatar
B3K
Dont know about inside but has a texture outside like a very fine sandpaper
Old Nov 20, 2005 | 11:59 AM
yea, thats rock chips from the road. ill get you the how to on repairing hazing headlights. Sorry, but its a mitsu that they do it on.
Old Nov 20, 2005 | 12:09 PM
I've seen it on plenty of 97-99 style headlights, and it's been bugging the hell out of me. It looks like dust and crap, but it's actually fine rock chips on the surface of the lense. After a couple tries I found a method that works for getting rid them..
You need grits 320,600,800, and 1500 of Wetordry sandpaper, Mother's metal polish, a rag, Plastic polish, and a buffing wheel (I used a plug-in Black&Decker 7" 2 speed, 3/4 HP buffer).
Start off by removing the entire headlight housing from the car. Begin wetsanding the surface with the 320 grit and KEEP IT WET. Take your time and make sure you sand equally over all of the lense. Keep at it with the 320 until the rockchips are gone. Next, move on to wetsanding with the 600 grit, then to 800, and 1500. I took at least 7-10 minutes with each grit for best results. Now, the lense should look really fogged up and way worse than when you started. This is normal!
Take a cotton rag and use it to rub metal polish across the lense. Begin buffing it by hand using the rag. Be generous with the metal polish and put some muscle into it. Take at least 10 minutes with this stage.
Now the lense should look clear, but no very glossy. Take another rag and use it to smooth plastic polish over the surface of the lense. Now use the powered buffing wheel to buff the lense until all the polish is gone and the lense is looking glossier. With an amazing 3/4 Horsepower-powered wheel, I had to secure the headlight housing between my feet. Do this 3 or 4 times.
If you completed all of the above the headlight lense should look as good as new. Stick the housing back in, switch on your lights, and be amazed.. It looks clean yo!
Here's a before/after comparison shot I took. The difference is day and night in person, and now I have no reason to burn $300 on projectors.
Old Dec 13, 2005 | 01:08 PM
BIGDADDY's Avatar
Why go through all of that when you can do it all in minutes? Go to a reputable auto parts store, and pick up some 3-M Plastic Cleaner, (they also make Plastic Pollish). Or you can use a medium cut rubbing compound mad for taking out paint scratches. Put a dab on a rag and rub for a couple of minutes. Finish up with the 3-M Plastic Pollish, or some regular old Windex. It will be blinging. But you got to do it every few months, same as with all that expensive sandpaper. You choose!
Old Aug 18, 2006 | 07:18 PM
virtual's Avatar
Go to http://www.prowax.com. There's a kit-HRK-10. Removes the hazing and roughness from old plastic lenses. Kit is self contained w/instruction, lubricating fluid, plastic polish, microfiber towel, and of course the different grade sand papers. Seen the demo at a detailer's convention. Really works. And by the way, the instuction uses a Mazda 6 headlight!
[IMG][/IMG] Good luck
[IMG]local://upfiles/431/91DDE6965430416DA61258ED67FC90C0.jpg[/IMG]
[IMG]local://upfiles/431/1CFF47E7C2624999918219D47715FD0C.jpg[/IMG]
Old Aug 22, 2006 | 05:29 PM
joedaplummer's Avatar
I have a 97 B4000 Same Problem
I use Mothers brand Chrome Polish and a little elbow grease. It lasts for a while and then when cloudy again I repeat.
daepeltz24
Apr 4, 2007 04:47 PM
curbs02
Jun 3, 2005 02:35 AM
Patsplace
Dec 18, 2004 04:58 AM
jayman
Nov 21, 2004 02:51 AM
daepeltz24
Apr 26, 2004 03:12 PM
