Gas pedal not working
Changed the car battery in my Mazda CX 9 and now the gas pedal won’t accelerate. What could be the issue? |
Were you having any issues beforehand?
Open the bonnet. Shut all the doors. Lock the vehicle. Disconnect the battery for a half an hour. Reconnect the battery. Unlock the vehicle. Start the engine. Let it idle for a minute. Drive it & see what happens. |
Is there a correlation between the battery replacement and losing acceleration |
Not really no.It's remotely possible you might of spiked the computer. Basically try the old " turn it off & back on again" trick.
Failing this, you will need a diagnostic code check. |
