Fuel Injector leaking
Recently replaced the fuel injectors on my '84 GSL-SE. I can't stop them from leaking where they plug into the fuel rail. Any suggestions?
RE: Fuel Injector leaking
Did you also replace the o-rings on top of the injectors, and if so where they the right size o-rings? How about the bottom seals, are they new, was there any spacers? If the rail can't pull down on the injectors for tight fit, are the injectors the right length? Should be able to twist the injector but not more up and down.
you probably shouldn't drive it untill you get it sorted out
