-   General Tech (https://www.mazdaforum.com/forum/general-tech-6/)
-   -   Found this FREE codes website (https://www.mazdaforum.com/forum/general-tech-6/found-free-codes-website-2221/)
bengy678 02-15-2006 07:44 PM
Hi All
I had a problem with my 95, 323. The Check Light was on the dash, so I had a look around the web for on
how to read the codes.
Came across this site www.auto-diagnostic-codes.com
Has FREE code info on Engines, ABS, Auto Trans, Airbags.... for cars from US, European, Australian
and Japanese and Korean vehicles.
I was able to follow the instructions to read my engine codes, and then type the code in the
system.
Code came up as Code 32: HO2S Heater Control Circuit High (Bank 1, Sensor 1)
I tested and replaced the sensor, and that fixed problem. Just thought this website might also help others.
easyliving 05-02-2007 01:04 PM
RE: Mazda Millenia S 1999
Hi All, can someone tell me the plug firing order for this vehicle.
JS 11-29-2007 10:52 AM
1-3-4-2
jbracefan1977 03-14-2009 11:00 PM
hey thanks! I could use some of this :)
Scottie 04-10-2009 02:09 AM
wat is the code of the bluetooth for the phone if it varies from car to car can u tell me where i can find it p0lease
Master P 07-11-2009 06:07 AM
The bluetooth code should be 0000.
jwelsh86 03-16-2010 11:24 AM
Thanks. This is helpful
Mazdasareawesome719 05-27-2011 07:35 PM
Do a google image serch for your engine size and year and you'll find alot of good pics on it.
Chunchine3 06-09-2011 12:06 PM
Very nice! The check engine light just came on yesterday on my 3 ('07) and I'm trying to do as much research as possible.
fluxcapacitor01 09-19-2011 02:42 PM
Check Engine Light
To all who have this light come on and want to know what causes it - it can be a number of faults which cause this light to illuminate. I have a problem with my service light being on and like you did some research. The conclusion was that I bought a small piece of test gear (from 'Amazon' here in the UK) called a 'CAN OBDII Scan Tool' which plugs into the OBDII socket in the Drivers footwell. This piece of kit will scan your engine management system computer and tell you what fault codes it has found and then you look it/them up in the the provided book and/or CD. The piece of kit also allows erasure of codes once the fault has been fixed and also resets the Check Engine Light. Check it out on Amazon before you buy to make sure it will work with your car -make & age. It cost me £12.00 plus £8.00 post and packing - worth every penny. There are more expensive and versatile similar pieces.
Hope the above helps someone.
