-   General Tech (https://www.mazdaforum.com/forum/general-tech-6/)
-   -   Ethenol Causing Rough Idle? (https://www.mazdaforum.com/forum/general-tech-6/ethenol-causing-rough-idle-17250/)
Hit The Road Jack Jan 19, 2009 03:47 PM
2004 Mazda3...5 door...55k on OD
Anyone else experiencing this?
virgin1 Jan 19, 2009 05:31 PM
RE: Ethanol Causing Rough Idle?
Ethanol, at least a <10% mix, should able to be compensated for by the ECU/PCM? If you are experiencing a rough idle my guess is that something else is wrong.
It could be a MAF that"s not happy, or a evap fuel valve solenoid that"s stuck open. These are two pretty common problems.
You might try cleaning the MAF first. Be careful to be gentle with it as it"s a rather sensitive piece. CRC offers a MAF sensor cleaner at your local parts store.
You might also try resetting the ECU afterward by disconnecting the battery for +/-10-30mins.
It just occurred to me as I was wrapping up this post, but how are your motor mounts... especially the upper, "fluid filled"one on the passenger side. A bad mount can also make the car seem to have a bad idle when it"s actually normal.
Hit The Road Jack Jan 20, 2009 05:49 AM
Thank you virgin1
The motor mounts could have been disrupted from one of the 2(light) rear endings we've experienced.
IMHO, ethanol is not a 'good thing'
Jack
virgin1 Jan 20, 2009 03:57 PM
That one in particular seems sensitive to dry rot and losing it"s fluid. They"re about $70 from Mazda but there are a few available on the AM too.
And I agree. Ethanol is not my favorite thing to run in my street car either. For one thing, fuel mileage is reduced, but the cost is not.
