Emergency Brake Adjustment protege 5
Old Jan 30, 2016 | 10:24 AM
#1savage's Avatar
Default Emergency Brake Adjustment protege 5
Hi all, new to the forum. I have been having issues with adjusting my e-brake. I have adjusted it 5 separate times, and every time I put everything back together, it works once, then comes out of adjustment. Any tips?
Thanks, Vince
Old Jan 31, 2016 | 05:20 AM
Disc or drum brake?
Old Jan 31, 2016 | 06:57 AM
#1savage's Avatar
Default e brake adjustment protege5
Disc, I have took the 14 mm bolt off and adjusted the allen screw and adjusted from the lever.same result . I think an excorsism is what I might try next !
Old Feb 1, 2016 | 05:20 AM
How old is the car?
How long since the brake fluid was changed?
Completely de-adjust the handbrake cable, undo the allen key, unbolt the caliper, fully push in the piston, pump the pedal a little to push the piston out alittle, push in piston fully. Refit caliper, pump pedal 50 times with engine running, wind the Allen key tight.back it off 1/3 turn.make sure disc spins freely. Adjust cable. See if this helps. Other wise calipers need rebuilding.
culch1
Jun 22, 2009 04:53 PM
JohnnyP
Oct 15, 2008 11:31 AM
jaeger
Jan 14, 2008 11:13 AM
mtarajia
May 15, 2007 02:24 PM
