CX-5 Voltage regulator spec
Any idea where I can locate the spec for the voltage regulator output spec, for a 2020 CX-5. All regulators are spec'd to high and low limits. Google failed me.
FYI, voltage regulator is controlled by the PCM. Battery voltage, ( which is different to Module or PCM voltage ) at idle with no loads should be 13v or above ( depending on Battery State of Charge SOC )
Do you have a specific question, or are you just curious?
