Crippled 626 in back yard
Bought a 626 one year ago for $250. Wouldn't pass emissions with 2 weak cylinders but runs better than the other 323 I posted here for advice. Still waiting to see if anyone has answers for a car that accelerates choppy but won't cut loose and run like a mazda should.
RE: Crippled 626 in back yard
thouroughly clean the injectors or carb, and the fuel lines, and you should notice a substantial increase in power and driveability. then do a full blown tune up. btw, what year ??
Appreciate your reply and will continue to work through fuel system cleaning and injectors. Have done tune-up and car did pass emissions. Just a weak acceleration and think it might even need fuel pump. Having a shop test pressures now.
Thank you bdmazda for the only reply... courtesy is commended-your suggestion was not the fix though!Goodbye forum members
