clutch kits
anyone that know about mx6 v6 plz help me out on what clutch to get for it,and what i need to buy in order to change the clutch or what ever.i was looking at a centerforce stage 1 for $187.38 and wanted to know if those clutches are good and if im getting a good deal on it but.i would like to know the specs on what clutch i can get for my mx6. Thanks
RE: clutch kits
well, the higher the "stage", the stiffer the clutch will be..clutches are rated by "pounds", and that is how hard they come together...also, a higher stage clutch has less slip to it..a friend of mine has a stage 4 clutch in his car, and it closes so hard that even at low rpms, it chirps the tires..also, it is VERY VERY hard to slip it at all
RE: clutch kits
Depends what how you plan on using the car. I mean, if you plan on drag racing, or just driving normal on the street. I am a bit older and out of my teen years and would go with stock for example. Also, if you have never replaced a clutch, or have limited tools, it would not be good to try unless supervised by an experienced tech.
