to babyhuey
thanks for all your help i found, the problem threw all the litle things u sent me it ended up being the two plug -ins were switched on the two little drums undre the egr booste sensor so now there no light and she runs great thank for all the help you really know your stuff brother. your new friend andre from mass, how much do i owe you hahaha........
RE: to babyhuey
hahaha, how bout $100.:D Just kidding buddy. Knowing that all is now good and I have a new friend andre from mass is more than enough for me. So this whole time the boost sensor solenoid valve connector was swapped with the fuel pressure regulator solenoid valve connector. doh!!
RE: to babyhuey
ya im an idiot i know but sometimes it right in front of u thats u u dont see it haahahahahahahh but thanks again master huey if u ever need a retard or an addition on ur house give me a call. hahah latter bud
RE: to babyhuey
You are most definitely not an idiot oldmangt96. You solved the problem and the ones that are right in front of us are the most challenging. You were able to overcome that obstacle and see the problem for what it was without much help from outside. If I ever need help with an addition to my house I will most definitely call on you as you do not give up and continue to search for the answer that you know is correct. If you are ever in the Oregon area then give me a call. Looking forward to hearing from you again my friend.
