323 Bucks on throttle
Old Nov 5, 2007 | 08:44 AM
UniCav's Avatar
Default 323 Bucks on throttle
I really need some advice on my 89 323 1.6L Non-Turbo.
The car suddenly developed a problem last week and I have been unable to sort it out.
The car will crank and idles perfectly, smoothly with no stuttering, no smoke or smell,
but as soon as you apply throttle the engine will only rev up a bit and then bucks or chokes and then revs again.
It will do this over and over, never fully throttles up, keeps choking and revving again.
During this time the car smells really bad of gas but there's still no smoke.
I've pulled the trouble code several times, the only code is Code 1 - Ignition Pulse
I've changed the plugs and coil. The wires, cap and rotor all look fine. No sign of shorts or arcs and no carbon buildup.
Checked the fuel pressure and was only getting 25-45psi so we changed the filter and then the pump itself,
now I'm getting 65+psi but no change whatsoever in the problem.
I'm thinking Distributor since it's an ignition code but I'm also worried about the air meter.
Any ideas, suggestions, Thanks in advance.
Old Nov 6, 2007 | 04:25 PM
hixx's Avatar
Default RE: 323 Bucks on throttle
65 psi is way too high. Code 01 is ignition so either pickup coil/igniter, wiring to the ECU or ECU problems. Check the AFM flap for free movement and the boot from the AFM to throttlebody for cracks though as the surge is typical for a broken boot.
Old Nov 7, 2007 | 03:52 PM
UniCav's Avatar
According to the manual and other sources I've pulled 65-85psi is the requirement, but that's also under test conditions (no connection to the fuel rail, gauge installed right after the filter, pump activated manually). I've looked the entire air path over from air meter to throttle body and found no cracks or leaks. The tubes from the valve cover to the air intake are old and need replacing but they seem to be sealed fine. I've also run the car with those 2 holes plugged in the intake. I had planned to fix up a custom air tube without those and just run the crankcase feeds directly to the EGR with an open element filter on it's own to keep the oil out of the system when I ever found the right tubing.
I ohm'd out the AFM and it seems fine, air vane is working great.
Plugs/Coil/Wires/Cap/Rotor all checked so the next logical thing is the Distributor and Igniter Module. I'm trying to track one down now.
Old Nov 16, 2007 | 07:30 AM
UniCav's Avatar
Default Fixed
The trouble code was right. Ignition module in the distributor was bad.
nogoodwivcars
Oct 14, 2012 03:55 PM
newjersey1988
Dec 16, 2007 09:50 PM
radtech
Nov 18, 2007 07:55 PM
bjcarr
Aug 9, 2007 08:56 AM
eardrums
May 15, 2006 04:49 PM
