30,000 mile service-no need for cooling system/trans fluid service right?
Old 04-24-2018, 07:47 AM
daheld's Avatar
Default 30,000 mile service-no need for cooling system/trans fluid service right?
I've got a 2016 Mazda 6 GT. Currently has about 32,000 miles on it. This morning I dropped it off for it's 30,000 mile service, and just like they did for the 15,000 and 25,000 mile service (which I've declined both times), my dealer has tried to get me to do some extra service on the car besides the oil change/tire rotation and factory recommended service. I have seen varying opinions on this, so I wanted to get some input.
Verbatim from their flyer, the 30,000 mile "extras" they tried to sell me this morning were:
  • Cooling System Fluid Exchange Service: "We first install an safe and effective cleaner to remove scale and deposits from the engine and radiator components then power exchange all worn out, contaminated coolant with factory approved new coolant. Our technician finishes by installing BG Super Cool coolant to supplement to prevent corrosion and protect engine components. This service is part of the BG Protection Plan. See your advisor for details." $159.95
  • Synthetic Transmission Fluid Service: Utilizing state-of-the-art technology we will use a safe and effective cleaner to suspend harmful gums and varnish that form inside the transmission. Next we exchange all the worn out and contaminated fluid from the entire system with fresh factory approved fluid and finish the service by installing BG Automatic Transmission Conditioner to help protect seals and good shifting characteristics. This service is part of the BG Protection Plan. See your advisor for details." $199.95
First, no, I did not purchase any kind of extended protection plan and I've always declined these. These both sound like ridiculously expensive fluid flushes to me, and I just cannot see how the car could ever need this at 30,000 miles. For one thing, THE TRANSMISSION WAS REPLACED AT 20,000 miles!
At 15,000 miles, they tried to sell me a "engine performance service", and at 25,000 miles they wanted me to do a "power steering fluid exchange service" and a "brake fluid exchange service". Again, I cannot see how any of these need changed so soon. So--they're just trying to upsell me a bunch of BS that doesn't need to be done, and isn't even factory recommended, right?
Old 04-24-2018, 07:56 AM
shipo's Avatar
Ask them to show you in writing where Mazda recommends such service; under the assumption they cannot (and they can't), ask them to put in writing their recommendations and then forward them on to Mazda USA.
Old 04-24-2018, 11:08 PM
Coolant should be FL22 long life 10yrs or 200,000kms/ 125,000miles.
Do you do any towing? Lots of round town driving? if so, you trans fluid maybe getting worn out, but I highly doubt it. A flush at 60,000miles isn't a bad idea.
Old 01-26-2022, 09:03 AM
Anjan's Avatar
Default Transmissions run hot 60k service is good
I fully agree transmission service at 60 k is good. I am taking 2019 cx 5 to the dealer for a flush and fill vehicle has 50000 miles. I have been working on cars since 1972 I had recommended and performed tranny service every 2 years or 24000 miles on older cars. My dealer in Clermont Florda has quoted $139 I am having it done.
Old 01-26-2022, 01:34 PM
I would reconfirm EXACTLY what this service is. That is actually to low... Sounds to me like maybe a 4-5 quart filter only service and even that is a little low priced? Now maybe that was the labor only which would be closer to correct?
Old 01-26-2022, 03:13 PM
Anjan's Avatar
Default I agree mostly labor.
Yes it's mostly labor with maybe 3.7 quarts fluid. It's extremely cold here in Clermont Florida, without a lift lying on the floor is not worth it.
Old 01-27-2022, 03:14 PM
Ok so not a full fluid replacement only a transmission filter service.
Old 01-27-2022, 09:21 PM
Anjan's Avatar
Default Transmission drain and fill
Transmission drain and fill with filter.
Siva Praneeth
01-26-2022 03:21 PM
nfenimore
09-04-2020 12:14 PM
mrdoow
07-26-2020 11:33 AM
MrSpike118
03-24-2012 12:29 PM
04tributelxowner
07-13-2007 08:29 PM
Quick Reply: 30,000 mile service-no need for cooling system/trans fluid service right?
