2014 CX5 - do i have sat nav?
hi, first post here
just bought the wife a used CX5 2.2d
loving the car, but wondering about sat nav
it has the button, but doesn't seem to work
searched in google, but unsure what i need to get it working
thanks in advance
jim
thanks in advance
jim
Hey jim, I recently did this to a cx-5, most of the wiring looms are the same from model to model, if it has the nav button then you could add the necessary parts to make it work, if your car is a uk right hand drive car there’s a small compartment for change I suspect, on the lower right of the steering wheel, this can be removed and a sd card reader installed, you will need to purchase this, and a sd card containing maps, you will also need too purchase a gps antenna which sits behind a speaker panel on the top of the dash, no reprogramming required
good luck
good luck
