1990 626 died & won't start
Hello, I'm a new guy to the forum in need of some help. I was driving my 626 work car home when slowing down to stop it died. I have no spark & don't think the fuel injectors are putting fuel to the motor. I replaced the distr.,cap & rotor. also replaced the external coil. Can anyone help? Thanks Burchett out
RE: 1990 626 died & won't start
Pull the distributor cap back off and with someone else cranking the engine, make sure the distributor rotor is turning. Could have broken and timing belt and this is a easy check to see if that is the case. No rotor turning equals either broken timing belt or camshaft.
Hello again, I replaced the rotor, cap, ignitor, & external coil. I am starting to think maybe a relay is not working. I have dash lights but no spark or injector noise, I can not smell any fuel smell and all plugs are new and dry. Timing belt is new, I am lost with this no spark no fuel problem. I use the car to drive to and from work to keep miles off my large Super Duty Diesel (of course) Thanks to all that has and will posts.
Burchett out |
So I assume that the distributor is turning when cranking the engine??
Do you have power to the White w/ Red stripe wires at the fuel injectors. Do you have power to the postive side of the ignition coil. This would be the Black w/ White stripe wire side. If you do have power to the positive side of the coil then does the negative side flash with engine cranking over and a 12 volt test light on the negative side of coil. Clamp end of test light on negative battery post? |
sounds to me more like a broken wire, these kinda problems are generally pretty simple problems but hard to find, check the feed wires and terminals into the coil, don't really know the engine..
