08' Trunk popper/electric product??
Hi!
I'm getting my 08' Mazda 6 Sedan/Saloon next week. And I noticed it had a button on the trunk to pop it open, I was wondering, are there any products either electric or just a spring that drags it all the way up that fit this model? I've seen some Russian videos of people opening it via remote even!!! All tips are welcomed=) |
Good day, so im considering getting a nicer 2-way alarm for the mr2. Probably a viper or compustar machine (now not sure which is better/nicer. I want extra research) anyway, maximum have an output for the trunk, and mr2's have a cable actuated trunk so i was bummed that i couldnt use that alternative HOWEVER, my jetta has a mechanical linkage setup and it makes use of a electric actuator that pushes the lever over while the trunk button is pushed. (inventory on the auto) so my idea is, get a pleasant low profile electronic actuator to push the discharge lever over in the trunk whilst i need the trunk poped from out of doors the car. Consequently giving me electronic manipulate of the trunk, as well as the inventory cable pull. Or i ought to even add a button inner and use the electronic actuator at the rush of a button to pop the trunk. No longer as beneficial, as the cable does its task, however technically i may want to :P has every person carried out this type of factor? Sounds without difficulty accomplished. BUT i may be incorrect and itll be hell trying to get it to work :P ideas/opinions on the problem?
192.168.100.1 192.168.1.1 |
