08 mazda3 Help check engine light ....
I've been having an issue with my 2008 mazda 3 auto.. This problem seems to occur when the weather is warmer ... I will be driving and the car will either shoot the revs sky high and loose speed or it will loose revs and speed at first I was able to pull over turn it of and on and it would be fine or I was able to put it into the manual mode and drive fine that way ( but that dosnt work now) but the problem has gotten worse now the check engine light comes on it does a sort of jerking motion while driving it has showed up codes one being a filter we replaced it then this time it has come up with the same code.. It also only ever does it on longer drives from an hour onwards and onu ever done it once around town pleaseeeeee help me :(
We have replaced a filter, oxygen sensor, and vac tube had transmission serviced .. It has never missed a normal service at all :confused: :( :( |
Need the exact codes. Engine and transmission codes.
