Electronics, Computer & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
Fan control module...need help
Old 06-13-2016, 02:09 PM
mazda6 guy's Avatar
Default Fan control module...need help
Is it normal for the cooling fans to only run intermittently when the AC is turned on, or should they run continuously?
Also, should the the cooling fan continue to run after the car is turned off, when the AC has been running?
I replaced the fan relay 6 months ago so I want to be sure it's still working correctly. I replaced it because the coolant fan kicked on as soon as the car was started (hot or cold) and continued to run at high speed after the engine was off. (during the winter when AC was NOT on)
Old 08-30-2020, 12:41 PM
winkybil's Avatar
Fan speed low and high work, but when medium is selected, absolutely nothing happens with the fan. It stops blowing. Any ideas what's up with that? Is it worth returning? Any tricks snaptube vidmate word to pdf to make medium speed work? Is it even a big deal?
gbh
07-23-2020 12:44 PM
mazda6 guy
06-12-2016 06:42 PM
mazda6 guy
06-11-2016 06:52 PM
parcou
07-15-2013 09:39 PM
MazdaSilva
05-06-2011 04:59 PM
Quick Reply: Fan control module...need help
