Electronics, Computer & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
Engine cranks, wont start
Old Jul 28, 2022 | 06:51 PM
Jovil's Avatar
Default Engine cranks, wont start
On a 1998 Mazda 626 2.0l. I have replaced several items to fix car vibration which was eventually fixed by replacing the gasket in the intake manifold which had a large leak. However, now the engine cranks but will start momentarily after priming with starting fluid. I replaced the fuel pump with no success. Throttle is clean, Air filter is clean and there are no error codes. So far I have replaced the following:
Fuel pressure valve
Fuel pump relay
MAF sensor
Both belts
Crankshaft position sensor
All fuel injectors
Throttle position sensor
Spark plugs
Spark plug cables
Distributor
All motor mounts
Downstream oxygen O2 sensor
Front oxygen O2 sensor
Idle control valve
Fuel filter
Some vacuum hoses
Fuel tank cap-tank is full
Fuel pump
mazdathang
Oct 11, 2021 02:06 PM
Joseph Spielman
Oct 11, 2018 02:45 PM
Luca
Dec 4, 2012 04:57 PM
pauly_yz
Sep 9, 2011 09:18 AM
ptempy
Sep 24, 2006 03:26 PM
