Ehps
I was given this today. Does anyone know how to hardwire one of these? I'm doing a conversion on another car I was told there's a can-bus interphase? I'm not sure can anyone help.
https://cimg1.ibsrv.net/gimg/www.maz...30c55bea85.jpg https://cimg3.ibsrv.net/gimg/www.maz...6006357571.jpg https://cimg6.ibsrv.net/gimg/www.maz...68a3179133.jpg |
I'm guessing its a electric power steering pump from either a BK or BL Mazda 3. What vehicle are you wanting to fit it to?
A little research done,
The big fat White wire is 80amp fused supply power The big fat black wire is earth The SB - Sky blue wire is a 7.5amp fused supply power The red & white wires are the high speed can network. |
Is there any way to make this work in another car or does it need mazda's control module? And thank you for the info
It's going into an old Mitsubishi, if possible. Wanted to convert to electro hydraulic to save a little space in the front but hours of research have lead me with no solution it's not as easy as an mr2 pump or a Volvo pump just needed a bit of information to see if this was possible.
I've got no idea on how its controlled.
Ok not a problem thank you for your help
Wiring info and CAN buss
(Post 177883)
The big fat White wire is 80amp fused supply power The big fat black wire is earth The SB - Sky blue wire is a 7.5amp fused supply power The red & white wires are the high speed can network. I managed to get hold of one, but cant seem to find wiring info Would be able to find the CAN bus info if can work out wiring info Will just get logs off a car, and play back message and keep removing some till down to minimal needed to make run Would you know where could down load manual for this car, can find that info if has wiring diagrams This thread had some good info, nothing on controlling it though and not my pump https://www.diyelectriccar.com/threa...ps-pump.19505/ https://cimg6.ibsrv.net/gimg/www.maz...f85ef3740d.jpg 2006 Mazda Axela plugs |
Found wiring info for Mazda 3
Have wiring info now
Just need to interface with the CAN bus and see what message need to be sent Plus find a Steering Angle sensor https://cimg5.ibsrv.net/gimg/www.maz...2f454accea.png |
| All times are GMT -5. The time now is 06:11 AM. |
