Electronics, Computer & Fuel Systems Talk about the powertrain control module, fuel systems and delivery, customization and more.
Ehps
Old Oct 2, 2019 | 05:56 PM
pat026's Avatar
Default Ehps
I was given this today. Does anyone know how to hardwire one of these? I'm doing a conversion on another car I was told there's a can-bus interphase? I'm not sure can anyone help.
Old Oct 5, 2019 | 01:07 AM
I'm guessing its a electric power steering pump from either a BK or BL Mazda 3. What vehicle are you wanting to fit it to?
Old Oct 5, 2019 | 01:23 AM
A little research done,
The big fat White wire is 80amp fused supply power
The big fat black wire is earth
The SB - Sky blue wire is a 7.5amp fused supply power
The red & white wires are the high speed can network.
Old Oct 5, 2019 | 05:32 AM
pat026's Avatar
Is there any way to make this work in another car or does it need mazda's control module? And thank you for the info
Old Oct 5, 2019 | 05:37 AM
pat026's Avatar
It's going into an old Mitsubishi, if possible. Wanted to convert to electro hydraulic to save a little space in the front but hours of research have lead me with no solution it's not as easy as an mr2 pump or a Volvo pump just needed a bit of information to see if this was possible.
Old Oct 5, 2019 | 06:18 AM
I've got no idea on how its controlled.
Old Oct 5, 2019 | 06:29 AM
pat026's Avatar
Ok not a problem thank you for your help
Old Aug 19, 2021 | 05:44 PM
True_Soln's Avatar
Default Wiring info and CAN buss
Would you know what the plug info is for the 2006 Axela pump
I managed to get hold of one, but cant seem to find wiring info
Would be able to find the CAN bus info if can work out wiring info
Will just get logs off a car, and play back message and keep removing some till down to minimal needed to make run
Would you know where could down load manual for this car, can find that info if has wiring diagrams
This thread had some good info, nothing on controlling it though and not my pump
https://www.diyelectriccar.com/threa...ps-pump.19505/
2006 Mazda Axela plugs
Old Aug 20, 2021 | 03:11 AM
True_Soln's Avatar
Default Found wiring info for Mazda 3
Have wiring info now
Just need to interface with the CAN bus and see what message need to be sent
Plus find a Steering Angle sensor
tanprotege
Sep 20, 2013 05:01 PM
TheGlassMaker
Jul 9, 2013 12:05 PM
Mazmart Trini
Feb 4, 2009 05:15 PM
6Pack
Feb 24, 2006 11:05 PM
