Easiest way to get power to the amp!!
Only works for Automatic!!!!!!
After searching the forum for a way to get the amp power wire to the trunk I could find NOTHING!!!!!!! ---Soo I had to go fishing!:eek: 1- Remove Battery and mount that batt sits on 2- Look for a oval looking piece of plastic where clutch would be. ( Behind batt on firewall- on inside- under steering wheel) 3- Find right size drill bit. 4- Drill thru ( You might need to drill from outside in and vice versa 5- Feed wire thru 6- Listen to your system bump!:D:D Any questions let me know!! |
