-   Audio/Visual Electronics (https://www.mazdaforum.com/forum/audio-visual-electronics-10/)
-   -   2016 CX-3 Entertainment system (https://www.mazdaforum.com/forum/audio-visual-electronics-10/2016-cx-3-entertainment-system-56085/)
RayWilk48 Sep 27, 2025 07:07 AM
I'm a new Madza owner so I 'm unfamiliar with a lot of the systems. I have some questions relating to playing audio through my phone, a Samsung Galaxy A35 which has successfully connected via Bluetooth. I can play music OK but on the display there is a square box on the right that I assume is for artwork but mine is always blank although I do have album artwork in the properties of each track. Also on the bottom of the screen if I select Root Menu it tells me it cannot browse the connected device. Is this an issue with Bluetooth devices? Would it make a difference if I use an SD card or some other type of device? Any help would be appreciated. Thanks, Ray
grim_reaper Sep 29, 2025 12:35 AM
Music on a USB stick might be better.
