Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Lowering an '04 Mazda 3 Hatchback!
Old 11-28-2016, 11:05 PM
LLong's Avatar
Default Lowering an '04 Mazda 3 Hatchback!
Just bought an '04 Mazda 3 hatchback, and the car needs new front struts and strut plates. the car will be my daughters car soon, and she wants to lower the ride a little bit. Asking around, and not getting a definitive answer do I want lowering springs like the eibach's or do I want coil-overs? Anybody have advice on what I should want for an everyday driver that I'll be giving to a 17-year old soon.
Also, if I go with lowering springs, are there specific struts that go with the lower/shorter springs of will any aftermarket strut work?
Old 11-29-2016, 01:54 PM
Eibach's offer the best ride, are easy to get and not that expensive. Koni STR.T shocks also for a better ride.
I am running H&R springs and Koni Sports (yellows) and for the street the ride can be a little harsh at times.
Coilovers are expensive and require a lot more attention during their lifetime.
I would also recommend installing the adjustable upper rear links, and clearly a 4-wheel alignment after. Have the shop dial back the rear camber to just under -1*. If wanting to go even further, the HD front anti-sway bar links from an '06 work well, but you will need to drill out the OE bar for fitment. And the Racing Beat 28mm rear bar to counteract understeer.
2004Mazda6s
12-11-2009 05:11 PM
91hatch323
02-13-2008 03:36 PM
whitetiger9188
05-23-2007 09:37 AM
mikeryan161
09-12-2006 11:35 AM
bassment_3
07-13-2005 01:13 PM
Quick Reply: Lowering an '04 Mazda 3 Hatchback!
