Tachometer Install Help
Old Jul 12, 2009 | 12:32 PM
Burton001's Avatar
Default Tachometer Install Help
Hey 2008.5 Mazda 3 trying to install 52mm tach, what wire will read for rpms, any help?? Thanks
Old Jul 13, 2009 | 04:35 AM
Tracker's Avatar
why....you already have a stock one that works right? so why add such a worthless gaudy item, the slow and the curious movie has been out for a while now so there is no need to rice your ride
Old Jul 14, 2009 | 09:36 AM
Burton001's Avatar
EDIT: Please refrain from making verbal attacks on other members, and ESPECIALLY on moderators. Continuing to do that will result in you being banned. -icspots
Old Jul 14, 2009 | 12:51 PM
VB's Avatar
VB
Regardless of what you think, Tracker is right. The only thing a large tach like that will do for you is make you look silly.
They're best left for drag cars or anything other car that's being raced, where you need such a big display for your RPMs. Assuming you get all the leads taken car of, where will you mount it?
Btw, calling something "gay" is not only ignorant, but makes you look even worse. I'd advise you against it. Then again, that's also a comment that has nothing to do with your question, innit?
Old Jul 14, 2009 | 04:16 PM
apbbnbanb_07's Avatar
It's getting kinda tense in here, I'm just gonna keep quite and move to the next post.
Old Jul 14, 2009 | 10:04 PM
icspots's Avatar
To the OP: Please see my comment above. If you're that offended by someone disagreeing with you then the internet is going to be a really difficult place for you.
Now that we're through with that..... I'm not sure what wire you would need to tap to get the tach signal for your new auxiliary tach, so I can't really help you out there. I second that I'm not really sure why you're installing a new one...... generally people install large tachs on their cars because they either: A) don't have one already, or B) they're racing with high horsepower cars where raising the rpms to high too fast will result in blowing up their car so they want a large visible gauge.
Incidentally what is your reason for installing one? Where are you planning on mounting it...... dash mounted, pillar mounted, custom housing, etc., etc.? What features are you looking for that the stock one doesn't provide? Which one did you decide on?
Old Jul 15, 2009 | 08:50 AM
BRIAN MP5T's Avatar
There is no such wire.
The factory cluster uses what is called a CAN BUS.
It works like a computer network.
The only way would be to install an AUTOMETER TACHOMETER ADAPTER on the ignition system.
I had one on my P5 for the longest time. Works very easily, is a pain in the *** to install and I have two of them sitting in a box if you want it..
http://www.autometer.com/download_instruction/0561B.pdf
Old Jul 15, 2009 | 08:15 PM
Me too. WHEW!!
dandym
May 27, 2016 04:53 PM
mazda_guy666
Jan 21, 2010 07:02 AM
local795
Feb 28, 2009 01:56 AM
rkthoka
Dec 28, 2007 03:45 PM
dgaf3888
Oct 16, 2007 08:01 AM
