Leaking clutch fluid???
RE: Leaking clutch fluid???
you also want to check the master cylinder, if the plunger in it is worn or cracked, you will leak amounts of fluid that may not be seen on the ground. I had this problem in the past, and it is a relatively cheap fix yourself, and not very time consuming.
unknownrsx
03-19-2008 11:33 PM
